Введение
In this guide, we will be showing you how to remove and replace the Memory Module.
Запчасти
Никакие детали не требуются.
  1. Slide and click the battery release latches to keep them open.
    • Slide and click the battery release latches to keep them open.
      • Slide the battery out of the bay.
  2. Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
      • Ease the hinge cover up, moving from right to left, and remove it.
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
      • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
        • Lift and remove the keyboard.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the memory module from the connector.
Финишная черта
Johnathan Hammond
Участник с: 28.02.2018
35 851 Репутация
Автор 408 руководств
Команда
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
15 членов
Автор 925 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 15
