Выберете то, что вам нужно
Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
Lift the clip to release the keyboard cable and disconnect it from the computer.
Remove the screw that secures the access panel to the computer.
Remove the screws that secure the display-hinge cover to the computer
Remove the display-hinge cover from the computer.
Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
Disconnect the power LED cable and the LED board cable from the system board.
Remove the screws that secure the palmrest to the front of the computer.
Pry along the edges of the palmrest to release the palmrest.
Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
4 участников успешно повторили данное руководство.
