Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Slide the left and the right battery release latches to the unlock position.
    • Slide the left and the right battery release latches to the unlock position.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
  3. Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Pry up the second keyboard retainer.
    • Pry up the second keyboard retainer.
  5. Pry up the third keyboard retainer.
    • Pry up the third keyboard retainer.
  6. Pry up the fourth keyboard retainer.
    • Pry up the fourth keyboard retainer.
  7. Pull up the keyboard from the palm rest.
    • Pull up the keyboard from the palm rest.
  8. Release the latch on the system board connector, then disconnect the keyboard cable.
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Loosen the screw that secures the memory door.
    • Loosen the screw that secures the memory door.
  10. Pry up the memory door near the screw hole, lift and remove it.
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Remove the screw that secures the optical drive to the computer.
    • Remove the screw that secures the optical drive to the computer.
  12. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  13. Gently pry the optical drive out of the computer.
    • Gently pry the optical drive out of the computer.
  14. Remove the screws that secure the optical drive bracket.
    • Remove the screws that secure the optical drive bracket.
  15. Remove the optical drive bracket from the optical drive module.
    • Remove the optical drive bracket from the optical drive module.
  16. Remove the screws in the battery compartment.
    • Remove the screws in the battery compartment.
  17. Remove the screws in the optical drive compartment.
    • Remove the screws in the optical drive compartment.
  18. Remove the rubber from the bottom base on the right side.
    • Remove the rubber from the bottom base on the right side.
  19. Remove the rubber from the bottom base on the left side.
    • Remove the rubber from the bottom base on the left side.
  20. Remove all the screws from the bottom base.
    • Remove all the screws from the bottom base.
  21. Flip the computer around and remove the screws that secures the palm rest.
    • Flip the computer around and remove the screws that secures the palm rest.
  22. Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  23. Release the latch on the system board connector and then disconnect the power button cable.
    • Release the latch on the system board connector and then disconnect the power button cable.
  24. Release the latch on the system board connector and then disconnect the hot key cable.
    • Release the latch on the system board connector and then disconnect the hot key cable.
  25. Pry up the right side of the palm rest.
    • Pry up the right side of the palm rest.
  26. Pry up the left side of the palm rest.
    • Pry up the left side of the palm rest.
  27. Pry up the sides of the palm rest and remove it from the computer.
    • Pry up the sides of the palm rest and remove it from the computer.
  28. Remove the screws that secure the display hinge.
    • Remove the screws that secure the display hinge.
  29. Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  30. Disconnect the LVDS cable from the system board.
    • Disconnect the LVDS cable from the system board.
  31. Disconnect the wireless local area network (WLAN) antenna cable.
    • Disconnect the wireless local area network (WLAN) antenna cable.
  32. Remove the screws that secure the left hinge.
    • Remove the screws that secure the left hinge.
  33. Remove the screws that secure the right hinge.
    • Remove the screws that secure the right hinge.
  34. Lift the display assembly and remove it from the computer.
    • Lift the display assembly and remove it from the computer.
Финишная черта
3 участников успешно повторили данное руководство.
Johnathan Hammond
Участник с: 28.02.2018
37 484 Репутация
Автор 408 руководств
Команда
Informative Technologies Inc. Участник Informative Technologies Inc.
Community
25 членов
Автор 1 823 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 446
