Введение
In this guide, we will show you how to remove and replace the Keyboard.
Выберете то, что вам нужно
Slide the left and the right battery release latches to the unlock position.
Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
Release the latch on the system board connector, then disconnect the keyboard cable.
It is also required to loose the screw just beside the latch mentioned in this step.
Еще один человек закончил это руководство.
