Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
In this guide, we will be showing you how to remove and replace the Hard Drive.
Запчасти
Детали не указаны.
  1. Slide the release latches to unlock the battery.
    • Slide the release latches to unlock the battery.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Remove the screws that secure the access panel to the base of the computer.
    • Remove the screws that secure the access panel to the base of the computer.
  4. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Lift the access panel up at an angle and remove it from the computer.
    • Lift the access panel up at an angle and remove it from the computer.
  6. Remove the screws that secure the hard drive to the system.
    • Remove the screws that secure the hard drive to the system.
  7. Lift up the hard drive at an angle from the system and remove.
    • Lift up the hard drive at an angle from the system and remove.
  8. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
Финишная черта
Еще один человек закончил это руководство.
Johnathan Hammond
Участник с: 28.02.2018
36 995 Репутация
Автор 408 руководств
Команда
Informative Technologies Inc. Участник Informative Technologies Inc.
Community
21 членов
Автор 1 816 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 107
