Введение
In this guide you will replace the hard drive in your Vostro 3560 Laptop. Some of this guide was made with information from this video.
Выберете то, что вам нужно
Make sure you have the right laptop by checking the sticker.
Start with your PC shut off and upside down.
Pull out tabs.
Pull up on rail to remove battery.
Remove the two screws:
One M2 Phillips screw (Fixed)
One 5-mm M2 Phillips screw
Remove the three 2.8-mm M2 Phillips screws.
Once you have removed the screws, gently pull the tab up to disconnect the hard drive.
Remove the hard drive assembly from the frame by pulling it straight up.
After removing the hard drive assembly from the frame, remove the four 3-mm M3 Phillips screws.
Once the screws are removed, remove the hard drive from the hard drive frame.
2 человек успешно провели ремонт по этому руководству.
