Введение
The first step in replacing the internal components of the Dell Vostro 15 5510 is to remove its back cover. To complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool.
Выберете то, что вам нужно
Remove the remaining (M2x4mm) screws with the screwdriver.
Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
Pry open the top left corner of the cover with the opening tool.
Pry open the top right corner of the cover with the opening tool.
Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
Pull the securing clips from both sides of the memory module outwards until the memory board pops up.
Remove the memory board from the memory-module slot.
