Введение
In this guide, we will be showing you how to remove and replace the Hard Drive.
Выберете то, что вам нужно
Unlock the battery by sliding the battery-lock latch towards the outer edge.
Slide the battery-bay release latch and hold it.
Remove the battery from the battery bay.
Remove the two screws securing the hard drive assembly to the system board.
Holding the connector end of the hard drive assembly, pull the hard drive assembly from the system board connector.
Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
2 участников успешно повторили данное руководство.
