Запчасти
No parts specified.
  1. Pop the center cover open on the bottom cover.
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Carefully remove back panel after all screws have been  removed.
    • Carefully remove back panel after all screws have been removed.
  3. After the back panel has been removed, disconnect the battery to prevent electrical shock
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  6. Once all the screws have been removed the battery is now safe to extract
    • Once all the screws have been removed the battery is now safe to extract
  7. Unplug the trackpad cable.
    • Unplug the trackpad cable.
  8. Insert wisdom here.
    • Insert wisdom here.
  9. Use a Phillips #00 screwdriver to remove the 4 trackpad screws.
    • Use a Phillips #00 screwdriver to remove the 4 trackpad screws.
  10. Remove the trackpad.
    • Remove the trackpad.
Итог
2 участников успешно повторили данное руководство.
DJ Jackson
Участник с: 11.04.2017
354 Reputation
Автор 2 руководств
University of Memphis, Team S1-G2, Kim Spring 2017 Member of University of Memphis, Team S1-G2, Kim Spring 2017
UM-KIM-S17S1G2
3 членов
Автор 6 руководств
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 823
