Dell XPS 13 9360 Battery Replacement
Выберете то, что вам нужно
  1. Dell XPS 13 9360 Battery Replacement, Remove the base cover screws: шаг 1, изображение 1 из 1
    • Using your fingertips, open the system badge.
    • Remove the screw (M1.6x6) that secures the base cover to the palm-rest assembly.
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palmrest assembly.
  2. Dell XPS 13 9360 Battery Replacement, Remove the base cover: шаг 2, изображение 1 из 1
    • Starting from the back of the computer, pry up the base cover using a plastic scribe (spudger).
    • Lift the base cover off the palm-rest assembly.
  3. Dell XPS 13 9360 Battery Replacement, Prepare the battery for removal: шаг 3, изображение 1 из 1
    • Disconnect the battery cable from the system board.
    • Peel off the tape that secures the speaker cable to the battery.
  4. Dell XPS 13 9360 Battery Replacement, Remove the battery: шаг 4, изображение 1 из 1
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Remove the three screws (M2x2) that secure the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Заключение
To replace the battery & reassemble your device, follow these instructions in reverse order.
24 участников успешно повторили данное руководство.
Max Kletskov
Участник с: 04/22/20
40 307 Репутация
Автор 16 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 410 руководств
14 Комментариев
Thank you for the guide! This was not too tough a repair and now my laptop is as good as new!
Russ Williston - Ответить
Took me about ten minutes to do this on my spouse’s laptop. The parts that took the most time were unplugging the battery and peeling the speaker wire tape. I suspect someone that’s never opened a consumer electronic before could get this fix done in 10 - 40 minutes.
Christopher Hall - Ответить
I had some problems with the M2x2 screw on the lower left corner of the battery, which almost got stripped using the Phillips #0 from the iFixit kit. I had to remove the other screws first and then rotate the battery around the remaining one to loosen it a bit, then managed to unscrew it with the Phillips #1.
José Luis - Ответить
So impressed with the quality of the website, the clarity if the guide, the quality of the toolkit, all the packaging, and not least, the whole attitude and ethos of the company about avoiding waste and empowering self-help. A+, 5☆ rating all around.
JRK - Ответить
Great.
My battery had already been replaced by a Dell repair technician, so I found I had to temporarily displace a taped pair of wires, otherwise no pitfalls.
Other than the case is razor-sharp - beware running the spudger along the edge that you don't cut your fingers!
Patrick Martin - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 126
За последние 30 дней: 654
За всё время: 14,880
