Введение
Use this guide to remove or replace your laptop's solid-state drive. The solid-state drive is the laptop's main file-storage device. This guide contains simple steps, but the SSD is fragile so be careful when removing or replacing it.
Выберете то, что вам нужно
Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
Use your fingertips to lift the system badge open and reveal the single case screw.
Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
Peel off the display cable tape from the hard-drive plate.
Remove the two screws (M1.6x2.5) that secure the hard-drive plate to the system board with a Phillips 000 screwdriver head.
Gently slide and remove the solid-state drive from the solid-state drive slot (SSD not pictured in image).
2 участников успешно повторили данное руководство.
