Введение
Use this guide to remove or replace speakers in your Dell XPS 13 9365 2-in-1 laptop. The speakers in this laptop are embedded on the left and right sides and can be accessed by removing the base cover.
Выберете то, что вам нужно
Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
Use your fingertips to lift the system badge open and reveal the single case screw.
Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
Note the speaker-cable routing and peel off the tape that secures the speaker cable to the system board.
Use a Phillips #000 screwdriver to remove the four screws (M2x2) that secure the speakers to the palm-rest assembly.
