Dell XPS 13 9370 Battery Replacement
Выберете то, что вам нужно
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: шаг 2, изображение 1 из 1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: шаг 3, изображение 1 из 2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: шаг 3, изображение 2 из 2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: шаг 4, изображение 1 из 1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: шаг 5, изображение 1 из 1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Заключение
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 участников успешно повторили данное руководство.
Max Kletskov
Участник с: 04/22/20
40 307 Репутация
Автор 16 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 420 руководств
8 Комментариев
Is the battery an original dell battery?
mnyousafva - Ответить
Why doesn’t it say what tools are needed?
Noah Guirguis - Ответить
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Ответить
Instructions were perfect, thanks for the great guide!
surfdaworld - Ответить
Boom, in a good way! I fixed it!
Chris Cox - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 105
За последние 30 дней: 480
За всё время: 15,546
