Введение
Battery not lasting long or completely dead? Replace it (only screwdrivers required).
Выберете то, что вам нужно
Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
Pull aside the ribbon cable.
Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
Take out 8 silver screws that are holding the battery with a PH00 head screwdriver.
Six 3mm screws.
Two 5mm screws.
Lift the battery out.
6 участников успешно повторили данное руководство.
