Введение
Trackpad not responsive or not working at all? Replace it (only screwdrivers required).
Выберете то, что вам нужно
Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
Pull aside the ribbon cable.
With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
Six 3mm screws.
Two 5mm screws.
Lift the battery out.
Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
Place aside.
Еще один человек закончил это руководство.
