Введение
Use this guide to replace the track pad in the Dell XPS 13.
Выберете то, что вам нужно
Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
Pull the battery cable connector towards the battery to disconnect it from its socket.
If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
Open the display and press the power button for five seconds to drain any remaining charge from the system.
Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
Use tweezers to gently lift the upper-right corner of the track pad.
Remove the track pad by slowly pulling it up and away from you.
4 участников успешно повторили данное руководство.
