Введение
This guide will walk you through replacing the display assembly on your Dell XPS 15 9510 laptop. This step-by-step process is perfect if your assembly is damaged, cracked, or malfunctioning. Remember that the display assembly is fragile and to watch out for the case's sharp corners.
Выберете то, что вам нужно
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
2 Комментариев
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
