Введение
Removing the back panel of the Dell XPS 15 9510 laptop is the first step in many repairs. Underneath this panel, there are many delicate components, so having a safe and clean workspace is key. The screws are fairly small, so it may also be a good idea to have a small container to save them in.
Выберете то, что вам нужно
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
