Выберете то, что вам нужно
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
3 участников успешно повторили данное руководство.
