Введение
How to replace the memory modules of a Dell XPS 15 9530.
Выберете то, что вам нужно
Шаг 1 Unscrewing the Base-Cover Assembly
Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Шаг 3 Remove Battery
Careful: step 3 is sourced from a guide that's marked as in-progress.
Remove the screws that secure the battery to the palm-rest assembly.
Disconnect the battery cable from the system board.
Lift the battery off the palm-rest assembly.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the New memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
To reassemble your device, put the battery back in and reaffix the base-cover assembly to the system.
Еще один человек закончил это руководство.
