Введение
Removal of the screen will be covered in this guide. To successfully remove the battery, a #0 Phillips screwdriver, a T5 Torx screwdriver, tweezers, and a plastic spudger are needed. Be careful disconnecting cables as to not break them or their connectors.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
Еще один человек закончил это руководство.
