Введение
Before the majority of components can be accessed to be replaced, the back panel will need to come off.
Выберете то, что вам нужно
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
12 участников успешно повторили данное руководство.
