Введение
If your Dell XPS 15 9550 laptop will not power on without being plugged in or not hold a charge for an extended period of time, you may need to replace your battery.
Инструменты
Запчасти
Turn the laptop upside down.
Using a T5 Torx Screwdriver, remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, releasing the whole panel.
Using a Philips #00 Screwdriver, remove the seven 3 mm long screws from the perimeter of the battery.
Firmly grasp the black connector on both sides.
Carefully pull the connector towards the battery, releasing the connector and the battery from the laptop.
20 участников успешно повторили данное руководство.
Комментариев: 2
… Mais avec un prix imbattable, la batterie made in RPC arrive avec un connecteur très très épais !
Finalement il m’a fallu me résigner à forcer très durement l’intromission avec deux paires de pinces !!!
Barbare mais efficace ! C’est le contraire de out ce que j’ai enseigné pendant des années : “le connecteur approprié doit toujours s’insérer en douceur” Ben là … NON !
English translation:
… But with an unbeatable price, the battery made in RPC comes with a very very thick connector!
Finally, I had to resign myself to forcing the intromission very hard with two pairs of pliers !!!
Barbarian but effective! It’s the opposite of what I’ve taught for years: “the right connector should always fit smoothly” Well there… NO!
