Введение
If the laptop will not connect to wireless internet, you may need a new wireless card.
Выберете то, что вам нужно
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
Set the screw and metal holder aside.
Gently lift up each of the antennas (3) to disconnect them from the wireless card.
With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
The wireless card has been successfully removed!
4 участников успешно повторили данное руководство.
