Введение
If the display on your Dell XPS 15 9570 is damaged or will not turn on, you may consider replacing the display assembly. This do-it-yourself guide will walk you through each step of removing the display assembly from the rest of the display case.
The display assembly constitutes the front panel of the display portion of your Dell XPS. Other than the obvious signs of damage or malfunction, other symptoms may tell you it is time to replace the display. These include the appearance of “dead” pixels, splotches, or a screen that is having trouble reaching full brightness.
Before using this guide, you may check the settings on your device for brightness and contrast to see if the image cannot be corrected.
Check to make sure that you have all of the required tools and parts before beginning this guide. A steady hand and attention to detail is required to complete these tasks.
Be sure to power off the device before beginning work on any electronic application (see step one).
Выберете то, что вам нужно
Remove the ten 3mm T5 Torx screws located on the outer perimeter of the device.
Use a Phillips #00 screwdriver to remove the two 10mm screws under the flip up plate.
Remove the rear panel using a plastic spudger. Its easiest to start from the top and work your way to the bottom.
Using a plastic spudger, pull down on the connector towards the battery to disconnect it.
Use a Phillips #00 screwdriver to remove the two screws holding down the the display cable fastener.
Remove the yellow sticker holding down the connector.
Pull up on the black tab to disconnect the display connector from the motherboard.
Use a Phillips #00 screwdriver to remove the screw from the network card.
Disconnect the white and the black network wires by popping them up from the card with a spudger.
Remove the network card and set it aside.
Unscrew the three screws from the screen bracket in the upper right corner using a Phillips #00 screwdriver.
Pry the latch up with a spudger or using the display for leverage.
Unscrew the three screws from the screen bracket in the upper left corner using a Phillips #00 screwdriver.
Pry the hinge upwards with a spudger or using the display for leverage.
8 участников успешно повторили данное руководство.
2 Комментариев
I have a 9570 with a 1080 non-touch screen. This page lists an amazon screen that is 4k with touch. Looking at the product page, it does not mention the 9570 but does mention the 9560. Will the 4k touch screen work? I would like to make this upgrade but am skeptical.
