Введение
In this guide you will be removing four screws and unplugging the hard drive. This is a quick easy replacement. You may also need to reinstall windows after completeing the hard drive replacement.
Запчасти
Никакие детали не требуются.
  1. Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Unplug the battery indicator.
    • Unplug the battery indicator.
    • Find the hard drive
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
    • Gently unplug and remove the hard drive
Заключение
SHELDON SANTOS
Участник с: 19.03.2018
594 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team S4-G7, Covino Spring 2018 Member of UMass Dartmouth, Team S4-G7, Covino Spring 2018
UMASSD-COVINO-S18S4G7
3 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 2
За 7 дней: 3
За 30 дней: 31
За всё время: 142
