Введение
This guide will allow you to replace the keyboard completely. You may need to remove this in order to replace the screen.
Выберете то, что вам нужно
Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
Work your fingers underneath the cover. Then, delicately pull the cover off of the computer.
Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
Slowly lift the top of the keyboard and then pull the keyboard towards the screen.
Using a spudger, slowly open up the two black clips holding down both cables.
Separate the unfastened cables from the base of the computer.
Once the cables are detached from the keyboard, you may pull the keyboard away completely and set it aside.
3 участников успешно повторили данное руководство.
