Введение
Replace the Display for Dell XPS 17 L702X. This guide includes instructions for removing the WWAN and WLAN cards.
Выберете то, что вам нужно
Flip over the laptop so that the bottom battery compartment faces upwards.
While holding the tab, lift the battery out of its compartment.
Release the tab after removing the battery.
Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
Lift the hard drive up to remove it from the case.
Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
Unscrew the screw holding the optical drive with a Phillips screwdriver.
Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
Push and hold the tab inside the optical drive's opening with your index finger.
Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
Put the spudger below the black tab of the wider cable and push up to release.
Gently pull out the cable.
Insert the spudger below the black tab of the remaining cable and push up to release.
Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
Close the display, and flip the laptop over so that the bottom faces upwards.
Remove the two 16 mm screws with a Phillips screwdriver.
Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw.
Gently pull out the WLAN card.
Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach.
Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach.
Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself.
Gently pull out the WWAN card.
Unscrew four the 8mm screws directly under the keyboard with a Phillips screwdriver.
Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver.
Using the plastic opening tool, detach the connection from the cable to the board.
4 участников успешно повторили данное руководство.
4 Комментариев
I have a question, my dell xps 17 l702x is having display issues. I've had it for about 6 years now and was using the original battery for that whole time, ( I know that's a long battery life), but my battery died and replaced it (battery plus bulbs) and now the display goes in and out and looks like it crashes then within 20 seconds, it comes back. Wondering what's going on. Any help is appreciated
Does it “flicker”/”spazz out” really weirdly when only on battery power? Try going into the Intel control panel and disabling the “Intel Power Saving Technology”
dell xps 17 l702x sir could you please tell me the best place to buy replacement screen?
dell xps 17 l702x please tell me the screen product number, would you guys fix it if I send it over? Do you guys have any branches in Delhi India?
