Введение
This guide will show you how to remove and install the card fan from the Dell XPS 720 H2C. The procedure may be a little troublesome and so extra patience may be needed.
Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
The card fan is located at the bottom left corner of the computer.
Remove the cable connecting the fan to the motherboard.
Disconnect the fan from the cage housing by pressing down on the release triggers and pushing them to the right.
Slide each corner of the fan cage off of the rubber grommets attached to the fan.
3 участников успешно повторили данное руководство.
