Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
You have problems with your RAM? Not detected properly or would like to upgrade to higher capacity RAM? Then this guide is for you!
Выберете то, что вам нужно
Flip your device the other way around
Don't be confused that this device is black, its a skin
Grab your T5 Torx and identify the 10 torx screws
Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
Careful there are more screws, do not try to open yet!
Open the flap on the back of the laptop
There are two screws that need to be removed, please use a Philips 0 screwdriver
The backplate might not be easy to open
You can use a soft prytool to open the laptop easier
Don't insert the tool too deep or you might break the mainboard
Now, you should be able to remove the backplate
Locate the battery connection to the mainboard
Unplug the battery before doing anything else
You can use a pry tool to make this easier
Locate the RAM on the mainboard
Gently push down on the 2 outside tabs of the RAM stick you want to replace
While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up
Firmly grasp the RAM stick from the flipped up edge and gently pull out, releasing the RAM stick
Insert the new RAM sticks into the socket or reseat the one that is already there if the ram is not detecting properly
Make sure to align the RAM properly in the slot before pressing down
Then press down to have the RAM to seat in correctly
Plug battery back in
Place backplate on top again and reassemble
3 участников успешно повторили данное руководство.
