Введение
If your CPU is causing your laptop to be unresponsive, or if it is overheating and running at a slower speed, then this guide can be used to replace it in about 30 minutes. You will need a Flathead 3.0 Screwdriver, a Phillips #01 Screwdriver, an iFixit opening tool, and tweezers.
Выберете то, что вам нужно
Remove the four 5.0mm screws with a Phillips #1 screwdriver.
Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
Remove the fan cover.
Remove the four 0.1mm screws using the Phillips #1 screwdriver.
Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
Remove the wire bay near the fan.
Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
Gently pull upward while moving your hand side to side so the plastic holder will detach.
Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
