Введение
If your computer is still running hot after cleaning the fan, you should remove the heat sink to check that it is not damaged.
Выберете то, что вам нужно
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
First, unscrew the six screws that are holding down the fan and heat sink with a Philips #1 screwdriver. Then use a Phillips #1 to remove the single screw near the bottom of the heat sink.
Six Silver Chrome 5.8mm Phillips #1 screws
Use your fingers or a spudger to remove the power pin connecting the fan to the laptop by pulling it straight up off the motherboard.
Еще один человек закончил это руководство.
