Введение
Before you begin the RAM replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Выберете то, что вам нужно
Slide the button next to the battery and lift up on the lip of the battery edge.
Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
Еще один человек закончил это руководство.
