Dell c1760nw Clean main mechanics cleaning and making it work
Выберете то, что вам нужно
  1. Dell c1760nw Clean main mechanics cleaning and making it work, Remove error 007-371: шаг 1, изображение 1 из 1
    • Does your Dell C1760nw ( and some other LED/laserprinter models) show you incessantly the error 007-371? Then this repair guide is made for you!
  2. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the paper tray: шаг 2, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove the paper tray: шаг 2, изображение 2 из 2
    • Remove the front paper tray by slightly bending it carefully and angling it to release the peg from the hinge slot.
  3. Dell c1760nw Clean main mechanics cleaning and making it work, Remove front housing parts: шаг 3, изображение 1 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Remove front housing parts: шаг 3, изображение 2 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Remove front housing parts: шаг 3, изображение 3 из 3
    • Remove the bar at the top and the front. (It snaps out with a little effort.)
  4. Dell c1760nw Clean main mechanics cleaning and making it work, Remove TopCase: шаг 4, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove TopCase: шаг 4, изображение 2 из 2
    • Remove two srews from the front. And to take off the cover leverage remove the tabs diagonally from the front over the latching.
  5. Dell c1760nw Clean main mechanics cleaning and making it work, Continued: Remove TopCase: шаг 5, изображение 1 из 1
    • Carefully lift the cover (Attention: cable connection to the display is hanging there) and rack it to the back of the printer (move it back and forth to unhook the locking nipple): unplug the display connector (yellow lines) from the I/O board, unroute the cable and remove the cover.
  6. Dell c1760nw Clean main mechanics cleaning and making it work, Remove left housing part: шаг 6, изображение 1 из 1
    • Place the printer on the right side and remove the left side panel (there are 2 lugs under the printer)
  7. Dell c1760nw Clean main mechanics cleaning and making it work, Next: Remove the left housing part: шаг 7, изображение 1 из 1
    • Reposition the printer and hold the disengaged lugs in the disengaged position. Open the rear flap and slide the side panel backwards while moving away from the printer.
  8. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the WLAN card: шаг 8, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove the WLAN card: шаг 8, изображение 2 из 2
    • The WLAN card is secured with a screw-> remove it, carefully unplug the WLAN card and remove the WLAN bracket together with the cable
  9. Dell c1760nw Clean main mechanics cleaning and making it work, Remove I / O card: шаг 9, изображение 1 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Remove I / O card: шаг 9, изображение 2 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Remove I / O card: шаг 9, изображение 3 из 3
    • Loosen all connectors (pull plugs carefully out of sockets)
    • Pull both flexible cables out of sockets. Caution: the wider flexible cable has a base with lock. Lift it carefully with a fingernail, this releases the flexible cable and allows it to be easily pulled out of the socket.
    • I/O card is secured with 4 screws, loosen all 4.
    • There is another screw on the USB port: Loosen it
  10. Dell c1760nw Clean main mechanics cleaning and making it work, Remove metal plate (beneath I / O card): шаг 10, изображение 1 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Remove metal plate (beneath I / O card): шаг 10, изображение 2 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Remove metal plate (beneath I / O card): шаг 10, изображение 3 из 3
    • The metal plate under the I/O card (which holds the I/O card) is secured with 3 screws. Remove all 3 screws
  11. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the fan: шаг 11, изображение 1 из 1
    • The fan is secured to this plate with a screw (red arrow): Loosen the screw and unlock the locking device on the other side of the fan.
    • Remove the fan, disconnect the cables and plugs on the upper control board (no photo).
  12. Dell c1760nw Clean main mechanics cleaning and making it work, Unroute wiring harnesses: шаг 12, изображение 1 из 1
    • Unroute all cable harnesses on the left side from the guides.
    • Remove the cable guide bracket and hang it from the remaining cable harnesses on the printer.
  13. Dell c1760nw Clean main mechanics cleaning and making it work, Remove other components: шаг 13, изображение 1 из 1
    • A) Remove plastic bracket with gear for paper feed (2 screws) - No photo!
    • B) Remove main drive
    • C) Remove board with color control (4 screws)
  14. Dell c1760nw Clean main mechanics cleaning and making it work, B) Remove main drive: шаг 14, изображение 1 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, B) Remove main drive: шаг 14, изображение 2 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, B) Remove main drive: шаг 14, изображение 3 из 3
    • Loosen 4 screws
    • Pull the main gearbox carefully and straight off the printer. (Caution: loose gears!)
    • Last photo: This is what the dismantled main gearbox looks like: The completely muddy (color & grease) drive gear is the black (below)
  15. Dell c1760nw Clean main mechanics cleaning and making it work, C) Remove board with color control: шаг 15, изображение 1 из 1
    • Carefully pull the upper flexible cable out of the base
    • on the right side: 4 flexible cables with base lock. With fingernail: Open the lock, then carefully lift the flexible cable by the blue tab and remove it from the base. (hand)
  16. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the color control gear: шаг 16, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove the color control gear: шаг 16, изображение 2 из 2
    • Next, we remove the color control gear (black, large plastic bracket with 15 meshing gears (5 screws have to be loosened).
    • CAUTION when removing the bracket so that the gears do not fall out!
    • 2nd photo: removed condition and THE central problem: The paint particles have combined to form a sticky mass with the gear grease.
  17. Dell c1760nw Clean main mechanics cleaning and making it work, Washing the gearwheels ...: шаг 17, изображение 1 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Washing the gearwheels ...: шаг 17, изображение 2 из 3 Dell c1760nw Clean main mechanics cleaning and making it work, Washing the gearwheels ...: шаг 17, изображение 3 из 3
    • Washing the gearwheels.
    • A toothbrush with plenty of hand soap brings good success here!
    • Attention: Every gear wheel has its position! Do not mix them up!
    • Attention: Dry all parts (brackets, gears) very well! "Knocking" the ingredients on paper towels helps!
  18. Dell c1760nw Clean main mechanics cleaning and making it work, First success: шаг 18, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, First success: шаг 18, изображение 2 из 2
    • The "before / after" evidence ;-)
    • I used low-viscosity grease to grease the axles and the teeth. Finally, add a splash of Balistol to the grease on the axles.
  19. Dell c1760nw Clean main mechanics cleaning and making it work, Second success: шаг 19, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, Second success: шаг 19, изображение 2 из 2
    • And once again: before and after
  20. Dell c1760nw Clean main mechanics cleaning and making it work, Clean the chassis: шаг 20, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, Clean the chassis: шаг 20, изображение 2 из 2
    • Now the chassis should be cleaned (only for the good feeling! and because of the care...)
    • Moist all-purpose wipes" in a resealable plastic cover are ideal for cleaning.
  21. Dell c1760nw Clean main mechanics cleaning and making it work, After assembly: шаг 21, изображение 1 из 2 Dell c1760nw Clean main mechanics cleaning and making it work, After assembly: шаг 21, изображение 2 из 2
    • The assembly is done in reverse order... Until the printer only needs the right and front housing part plus the paper flap.
    • If the error message 007-371 appears again at the first attempt of the printout, this is nothing unusual. The paint mixing drive usually still needs a "boost".
    • Turn the printer off and on again a short time later. Now you help the gear a little bit on the jumps: for this you put on a screwdriver as shown in picture 1, hold it with a little pressure so that you can get the gear wheel touched with it a little in motion when it is released by the small relay.
    • This usually does not happen by itself during the first printing process (although the spring in the gearbox, which you probably noticed earlier, should actually trigger this momentum). So, put on the screwdriver like this and send a print job.
    • In picture 2 you can see a better close-up to attach the screwdriver exactly.
    • If everything works, then reassemble everything else and: DONE!
Заключение
Congratulations, you did it!
5 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Прикрепленные документы
GeorgG
Участник с: 01/14/11
1 000 Репутация
1 руководство автора
3 Комментариев
could really use a service manual for the c1760nw if anyone has one. email is johnnysemail62@yahoo.com. Thanks in advance!
johnny - Ответить
do u have manual now?
dr.wot -
it looks so easy LOL but then when you know what your doing it helps!
Thanks all the same.
BC
Ben Cowell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 56
За последние 30 дней: 227
За всё время: 17,716
