Denim Jeans Inner Thigh Replacement
Выберете то, что вам нужно
  1. Denim Jeans Inner Thigh Replacement, Inner Thigh: шаг 1, изображение 1 из 1
    • Use a simple back and forth pattern with the needle and thread to close the holes.
    • This step is to ensure the shape of your patch. It will not be the outright fix to the problem.
  2. Denim Jeans Inner Thigh Replacement: шаг 2, изображение 1 из 3 Denim Jeans Inner Thigh Replacement: шаг 2, изображение 2 из 3 Denim Jeans Inner Thigh Replacement: шаг 2, изображение 3 из 3
    • Use an embroidery hoop as a stencil to trace out the damaged area.
    • Use fabric scissors to cut along the back panel of the jeans. Follow the line.
    • Cut only the back panel or you will have an unnecessary hole in the front of your pants.
  3. Denim Jeans Inner Thigh Replacement: шаг 3, изображение 1 из 2 Denim Jeans Inner Thigh Replacement: шаг 3, изображение 2 из 2
    • Place the cutouts in the denim swatch.
    • Trace a larger shape of the cutout.
    • Use fabric scissors to cut out the patches.
  4. Denim Jeans Inner Thigh Replacement: шаг 4, изображение 1 из 3 Denim Jeans Inner Thigh Replacement: шаг 4, изображение 2 из 3 Denim Jeans Inner Thigh Replacement: шаг 4, изображение 3 из 3
    • Center the old denim onto the new patch.
    • Trace vertical and horizontal lines on denim by using a straight edge and some chalk.
    • Pin the old denim in place.
  5. Denim Jeans Inner Thigh Replacement: шаг 5, изображение 1 из 1
    • Using an embroidery needle and an embroidery floss add stitches into the patch.
    • Use a Straight Stitch (just up and down sewing) following the vertical and then horizontal lines.
    • The embroidery floss comes as a twisted rope. You have to pull the threads from the rope before you can use them.
  6. Denim Jeans Inner Thigh Replacement: шаг 6, изображение 1 из 1
    • Pin the patch with as little of the new patch showing as possible.
    • Use a Whip Stitch to attach the patch. This is an over/under sewing pattern.
    • Repeat a second time.
    • Turn inside out and trim down the patch. Use a straight stitch to tighten up any loose spots.
  7. Denim Jeans Inner Thigh Replacement, Finished: шаг 7, изображение 1 из 1
    • The style is meant to look rustic and DIY. By no means is it a professional finish. Still functional and if done right can be quite cute!
Заключение
This is a rustic or unfinished but functional looking patch for denim jeans.
3 участников успешно повторили данное руководство.
chennaultsara
Участник с: 01/24/19
197 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 21
За последние 30 дней: 77
За всё время: 5,256
