Desktop PC Front Fan Replacement
Выберете то, что вам нужно
  1. Desktop PC Front Fan Replacement, Left Panel: шаг 1, изображение 1 из 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Ответить
    This is correct.
    DistroHopper39B -
  2. Desktop PC Front Fan Replacement: шаг 2, изображение 1 из 2 Desktop PC Front Fan Replacement: шаг 2, изображение 2 из 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Front Fan Replacement, Front Fan: шаг 3, изображение 1 из 2 Desktop PC Front Fan Replacement, Front Fan: шаг 3, изображение 2 из 2
    • Push to unlatch three grey connectors on the front panel.
  4. Desktop PC Front Fan Replacement: шаг 4, изображение 1 из 1
    • Disconnect the front panel from the computer face.
  5. Desktop PC Front Fan Replacement: шаг 5, изображение 1 из 1
    • Remove four Phillips #2 head, 5mm screws holding in the fan.
  6. Desktop PC Front Fan Replacement: шаг 6, изображение 1 из 1
    • Slide the fan out from the side of the casing.
  7. Desktop PC Front Fan Replacement: шаг 7, изображение 1 из 1
    • Disconnect the power cable from the fan.
Заключение
38 участников успешно повторили данное руководство.
David Lennon
Участник с: 04/14/15
9 944 Репутация
Автор 10 руководств
Команда
Cal Poly, Team 4-5, Maness Spring 2015 Участник Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 членов
Автор 45 руководств
Один комментарий
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 27
За последние 30 дней: 147
За всё время: 27,355
