Desktop PC Left Panel Replacement
Выберете то, что вам нужно
  1. Desktop PC Left Panel Replacement, Left Panel: шаг 1, изображение 1 из 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Ответить
    This is correct.
    DistroHopper39B -
  2. Desktop PC Left Panel Replacement: шаг 2, изображение 1 из 2 Desktop PC Left Panel Replacement: шаг 2, изображение 2 из 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
Заключение
23 участников успешно повторили данное руководство.
David Lennon
Участник с: 04/14/15
9 944 Репутация
Автор 10 руководств
Команда
Cal Poly, Team 4-5, Maness Spring 2015 Участник Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 членов
Автор 45 руководств
3 Комментариев
What is the name of the case used in this tutorial?
Nicolas Hunter - Ответить
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Ответить
I have this same case in black and want to know what model it is.
numanair - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 18
За последние 30 дней: 75
За всё время: 5,350
