Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Pull the edge of the pad where it meets the plastic of the ear-cup to separate the padding from the ear pad.
Use the small Phillips screwdriver to remove three 8mm screws on the surface of the earphones.
Now that the screws have been removed, use your hands to separate the plate from the rest of headphone.
Now that you have removed the plate you can check the wiring connectivity. If the wire is not connected to any sources inside the ear-cup, as shown in the image to the right, then this is the reason that your headphone(s) are not working.
Now that you have verified your problem, refer to the guide Skullcandy Lowrider Wiring Repair to fix the loose wiring.
