Введение
This guide will assist you on how to replace a Dewalt DCF885 Brush. The brush assembly is used to conduct electricity to the armature as they rotate in one direction from brush to brush. This will allow the motor to turn depending on the armature.
The brushes may wear out over time thus requiring a replacement which can be referred to using this guide and the tools down below. Before beginning, use a knife to cut the middle of the sticker located at the base of the handle for ease when disassembling the part.
Выберете то, что вам нужно
Separate the two halves of the outer case. Set the empty side down and out of the way.
3 участников успешно повторили данное руководство.
Один комментарий
Can you tell me the exact model number of the unit in this tutorial? And/Or the part number for that switch assembly? I cannot find that specific switch assembly anywhere! Thank you.
