Выберете то, что вам нужно
Unscrew the 6 Torx T5 screws from the back of the device
Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
Screen Information: Model AM0310R-04 Lot # NHT18080052
Using a spudger, unplug the Charging Port connector from the motherboard.
Using a spudger, carefully remove the battery connector on the left side of the motherboard.
Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
4 человек успешно провели ремонт по этому руководству.
10 Комментарии к руководству
@richy14330 The connector type is JST ACHR-03V.
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Andrew S -
