Dexter 750W Corded Jigsaw Motor Replacement
Выберете то, что вам нужно
  1. Dexter 750W Corded Jigsaw Motor Replacement, Unplug: шаг 1, изображение 1 из 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 750W Corded Jigsaw Motor Replacement: шаг 2, изображение 1 из 1
    • Remove the vacuum adapter from the back of the device.
  3. Dexter 750W Corded Jigsaw Motor Replacement: шаг 3, изображение 1 из 2 Dexter 750W Corded Jigsaw Motor Replacement: шаг 3, изображение 2 из 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
    • Use needle nose pliers and remove the clip located next to the blade holder.
    • Remove the blade holder, keeping the slider at the end of the holder.
  4. Dexter 750W Corded Jigsaw Motor Replacement: шаг 6, изображение 1 из 1
    • Unscrew the two screws and set them aside.
    • Remove the two carbons located next to the stator.
    • Lift the stator, then lever out the motor.
  5. Dexter 750W Corded Jigsaw Motor Replacement: шаг 9, изображение 1 из 1
    • Put the new motor back in its place.
  6. Dexter 750W Corded Jigsaw Motor Replacement: шаг 10, изображение 1 из 2 Dexter 750W Corded Jigsaw Motor Replacement: шаг 10, изображение 2 из 2
    • Collect the end cap on the old engine.
    • Put it back on the new motor.
    • Put some grease on the tip.
  7. Dexter 750W Corded Jigsaw Motor Replacement: шаг 11, изображение 1 из 1
    • Replace the two screws to stabilize the motor.
    • Return the blade holder to its location
    • Make sure you put each piece in its place.
    • Replace the staple in the same location. The curved side of the staple should go to the rounded side of the bracket.
    • Lubricate the whole
  8. Dexter 750W Corded Jigsaw Motor Replacement: шаг 14, изображение 1 из 2 Dexter 750W Corded Jigsaw Motor Replacement: шаг 14, изображение 2 из 2
    • Put the coals back in their places.
  9. Dexter 750W Corded Jigsaw Motor Replacement: шаг 15, изображение 1 из 1
    • Before closing, lubricate each gear.
  10. Dexter 750W Corded Jigsaw Motor Replacement: шаг 16, изображение 1 из 1
    • Close and screw the device.
Заключение
follow guide through or in reverse to reassemble
Особая благодарность этим переводчикам:
fr en
100%
HelloMacOS помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Céline Chemineau
Участник с: 01/29/20
16 698 Репутация
Автор 95 руководств
Команду
Leroy Merlin Участник Leroy Merlin
Community
38 членов
Автор 241 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 18
За всё время: 644
