DigiLand DL1010Q Motherboard Replacement
Выберете то, что вам нужно
  1. DigiLand DL1010Q Motherboard Replacement, Rear Case: шаг 1, изображение 1 из 1
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Motherboard Replacement: шаг 2, изображение 1 из 2 DigiLand DL1010Q Motherboard Replacement: шаг 2, изображение 2 из 2
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Motherboard Replacement: шаг 3, изображение 1 из 1
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  4. DigiLand DL1010Q Motherboard Replacement, Motherboard: шаг 4, изображение 1 из 1
    • Using a plastic opening tool, gently pry up the three Zero Insertion Force Connectors (ZIF)
  5. DigiLand DL1010Q Motherboard Replacement: шаг 5, изображение 1 из 2 DigiLand DL1010Q Motherboard Replacement: шаг 5, изображение 2 из 2
    • Using a Soldering station, desolder all 9 wires connected to the motherboard.
    • Start with the red and black positive and negative wires connected to the battery (2 wires).
    • Then move to the yellow and red twisted wires and black and red twisted wires connected to the speakers (4 wires).
    • Now desolder the single grey wire connected to the antenna (1 wire).
    • Lastly remove the black and red wires connected to the microphone (2 wires).
  6. DigiLand DL1010Q Motherboard Replacement: шаг 6, изображение 1 из 1
    • Using a J00 Philips screwdriver, unscrew the three black 4mm screws from the motherboard.
  7. DigiLand DL1010Q Motherboard Replacement: шаг 7, изображение 1 из 2 DigiLand DL1010Q Motherboard Replacement: шаг 7, изображение 2 из 2
    • Carefully lift motherboard in a upward motion.
Заключение
2 участников успешно повторили данное руководство.
Tyler Rise
Участник с: 09/28/15
335 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 1-5, Matresse Fall 2015 Участник Eastern Washington University, Team 1-5, Matresse Fall 2015
EWU-MATRESSE-F15S1G5
4 членов
Автор 10 руководств
2 Комментариев
How can I remove the CMOS battery?
solomon A.O - Ответить
I NEED dl1010q MOTHER BOARD
myukimages - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 1,074
