Введение
The DigiLand DL8006 is a modest and robust tablet. This guide will illustrate how to replace to the motherboard.
Запчасти
Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
Еще один человек закончил это руководство.
