DigiLand DL801W Speaker Replacement
Выберете то, что вам нужно
  1. DigiLand DL801W Speaker Replacement, Speaker: шаг 1, изображение 1 из 1
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Speaker Replacement: шаг 2, изображение 1 из 1
    • Remove the two JIS #000 screws that hold the speaker bracket in place. Be sure to place the screws in a safe place to avoid losing them.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective speaker.
    • Complete removal of the speaker from the motherboard is not necessary. It is just recommended that the bracket be removed to allow more room for battery removal.
Заключение
Travis Mangum
Участник с: 09/17/15
572 Репутация
Автор 4 руководств
Команда
IUPUI, Team 3-4, Harley Fall 2015 Участник IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 237
