Введение
If you need to replace your motherboard or inspect its solder connections, use this guide to remove it. Removing the motherboard will be necessary if you want to replace any other component of the device.
Выберете то, что вам нужно
Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Еще один человек закончил это руководство.
3 Комментариев
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
