Выберете то, что вам нужно
Шаг 1 Digiland 10.1'' DL1016 Remove Backing
Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Шаг 4 Digiland 10.1'' DL1016 Remove Battery
Careful: step 4 is sourced from a guide that's marked as in-progress.
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
Один комментарий
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
