Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, External Cover: шаг 1, изображение 1 из 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 2, изображение 1 из 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 2, изображение 2 из 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 3, изображение 1 из 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 3, изображение 2 из 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, Front/Rear Facing Camera: шаг 4, изображение 1 из 1
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  5. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 5, изображение 1 из 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 5, изображение 2 из 2
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  6. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 6, изображение 1 из 1
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  7. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: шаг 7, изображение 1 из 1
    • Finally remove the cameras.
Заключение
David DeMeritt
Участник с: 03/08/16
637 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 5-6, Landers Spring 2016 Участник UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 103
