Введение
We are going to teach you how to remove the buttons of your Digital2 Platinum Pad 9. This is a very simple guide and easy to follow and complete. But you will need to be able to identify components, you can learn how to do that by following this guide Recognizing & Disconnecting Cable Connectors.
Выберете то, что вам нужно
Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
Then just remove the backing.
You can locate the volume buttons on one of the longer sides of the tablet.
