Dirt Devil UD20005 Suction Path Replacement
Выберете то, что вам нужно
  1. Dirt Devil UD20005 Suction Path Replacement, Removing the Dust Cup: шаг 1, изображение 1 из 2 Dirt Devil UD20005 Suction Path Replacement, Removing the Dust Cup: шаг 1, изображение 2 из 2
    • Locate the dust cup latch and press down.
    • Pull outwards and up with the handle to remove the cup.
  2. Dirt Devil UD20005 Suction Path Replacement, Removing the Filter Assembly: шаг 2, изображение 1 из 3 Dirt Devil UD20005 Suction Path Replacement, Removing the Filter Assembly: шаг 2, изображение 2 из 3 Dirt Devil UD20005 Suction Path Replacement, Removing the Filter Assembly: шаг 2, изображение 3 из 3
    • At the bottom of the now vacant dust cup holder, locate the filter assembly and shroud. It is located just above the "Performance Indicator"
    • Pull up on the latch indicated and remove the shroud.
    • Be aware of any dust that may come off of the HEPA filter.
  3. Dirt Devil UD20005 Suction Path Replacement: шаг 3, изображение 1 из 2 Dirt Devil UD20005 Suction Path Replacement: шаг 3, изображение 2 из 2
    • Putting the shroud aside, use two fingers on the edges of the filter assembly to lift the rest of it out of its housing.
    • Note the slot that must line up with the filter during reassembly.
  4. Dirt Devil UD20005 Suction Path Replacement: шаг 4, изображение 1 из 2 Dirt Devil UD20005 Suction Path Replacement: шаг 4, изображение 2 из 2
    • Use a prying tool, such as a spudger, to separate the foam filter from the larger HEPA filter.
    • As mentioned previously, a lot of fine dust can kick up during this step, especially if your vacuum is extremely dirty. Consider using a mask if necessary.
    • The picture shows a pencil being used, which works fine, but take care to not puncture or otherwise damage the foam filter.
    • Set both of these aside with the rest of the filter assembly for cleaning later.
  5. Dirt Devil UD20005 Suction Path Replacement, Dust Cup: шаг 5, изображение 1 из 2 Dirt Devil UD20005 Suction Path Replacement, Dust Cup: шаг 5, изображение 2 из 2
    • Use a Phillips #2 Screwdriver to remove the dust cup shroud.
    • The shroud is cosmetic, but this will make future steps easier.
    • Remove the shroud by sliding it downwards over the dust cup slowly, working it off, being careful not to let it over-extend.
  6. Dirt Devil UD20005 Suction Path Replacement: шаг 6, изображение 1 из 1
    • On the bottom of the dust cup, locate the hinged door. Use the screwdriver to push the two hinge pins in to remove the door.
    • Set the door aside for cleaning.
  7. Dirt Devil UD20005 Suction Path Replacement: шаг 7, изображение 1 из 3 Dirt Devil UD20005 Suction Path Replacement: шаг 7, изображение 2 из 3 Dirt Devil UD20005 Suction Path Replacement: шаг 7, изображение 3 из 3
    • With the hinged door removed, look into the dust cup and locate the two screws holding the cyclonic funnel in place.
    • Use a #2 Phillips Screwdriver to remove them. The funnel will remove easily, place it aside for cleaning when finished.
  8. Dirt Devil UD20005 Suction Path Replacement: шаг 8, изображение 1 из 2 Dirt Devil UD20005 Suction Path Replacement: шаг 8, изображение 2 из 2
    • Grip the dust collector with your hand firmly, looking for the twist-lock that attaches it to the top of the dust cup.
    • Twist it clockwise and remove, setting it aside for cleaning.
  9. Dirt Devil UD20005 Suction Path Replacement, Cleaning the Filter Assembly: шаг 9, изображение 1 из 3 Dirt Devil UD20005 Suction Path Replacement, Cleaning the Filter Assembly: шаг 9, изображение 2 из 3 Dirt Devil UD20005 Suction Path Replacement, Cleaning the Filter Assembly: шаг 9, изображение 3 из 3
    • Rinse the filter shroud off in water. Particulates should come off fairly easy, as they should be small. If not, scrub lightly.
    • Rinse the foam filter off, working the particulates out with water, being careful not to damage the filter.
    • Run water through the HEPA filter in the opposite direction of the airflow. The water should be hitting the side that the foam filter usually is mounted on.
    • Place all three items somewhere to dry.
  10. Dirt Devil UD20005 Suction Path Replacement, Cleaning the Dust Cup: шаг 10, изображение 1 из 1
    • Run water through all the dust cup components, especially the dust collector, removing any lodged particulates or hair.
    • Make sure all components are completely dry before reassembly. Especially for the filter assembly, this can take up to a day.
Заключение
2 участников успешно повторили данное руководство.
Kyle Libby
Участник с: 04/07/14
1 006 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 7-23, Regan Spring 2014 Участник Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 членов
Автор 19 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 14
За всё время: 1,277
