Введение
It can be tricky to find all the potential blockages, so this guide will show how to find and then clean all of them.
Выберете то, что вам нужно
Locate the dust cup latch and press down.
Pull outwards and up with the handle to remove the cup.
At the bottom of the now vacant dust cup holder, locate the filter assembly and shroud. It is located just above the "Performance Indicator"
Pull up on the latch indicated and remove the shroud.
Putting the shroud aside, use two fingers on the edges of the filter assembly to lift the rest of it out of its housing.
Use a prying tool, such as a spudger, to separate the foam filter from the larger HEPA filter.
Set both of these aside with the rest of the filter assembly for cleaning later.
Use a Phillips #2 Screwdriver to remove the dust cup shroud.
Remove the shroud by sliding it downwards over the dust cup slowly, working it off, being careful not to let it over-extend.
On the bottom of the dust cup, locate the hinged door. Use the screwdriver to push the two hinge pins in to remove the door.
Set the door aside for cleaning.
With the hinged door removed, look into the dust cup and locate the two screws holding the cyclonic funnel in place.
Use a #2 Phillips Screwdriver to remove them. The funnel will remove easily, place it aside for cleaning when finished.
Grip the dust collector with your hand firmly, looking for the twist-lock that attaches it to the top of the dust cup.
Twist it clockwise and remove, setting it aside for cleaning.
Rinse the filter shroud off in water. Particulates should come off fairly easy, as they should be small. If not, scrub lightly.
Rinse the foam filter off, working the particulates out with water, being careful not to damage the filter.
Run water through the HEPA filter in the opposite direction of the airflow. The water should be hitting the side that the foam filter usually is mounted on.
Place all three items somewhere to dry.
Run water through all the dust cup components, especially the dust collector, removing any lodged particulates or hair.
2 участников успешно повторили данное руководство.
